- 19 Oct 2002
- Shakespeare’s County
It will be air suspension.
How did you lower it? Coil overs as standard or some fancy height levelling suspension?
Ruining an everyday car like in the OP is terrible, but meh, leave em too it. But when you take one of the best handling sports cars in the world and ruin that, I openly weep...
Yes that's about 10 degrees camber on the rear tyres
And yes, only about half the rear tyre tread width actually touches the ground
And yes, those are Nankangs
This makes me sad![]()
Ruined!
Ive known lots of cars where replacing worn out suspension with new but upgraded stuff actually improves the ride
Get a progressive spring (most Eibach Pros are progressive) and youve got a good chance of having a better than standard ride
Had my Mk3 MX5 lowered about 30mm by Wheels in Motion, to correct the high stock ride height. The result was a transformation in handling - grip, turn in, body roll were all much improved. On a nice drive, it was great fun.
However, there were negatives. The ride became very hard and on a bumpy road, the car didn't really inspire confidence, and never felt settled between bumps. It was quite uncomfortable on poorly maintained roads, and speed bumps and cushions had to be negotiated at a crawl.
If the car had been a weekend toy, it would have been fine. But it also had to double as my daily driver and in the end I spent more time getting annoyed with the negatives than enjoying the positives.
As for the coilovers I am going for on the MX5, I will be going for Meister R Zeta S - these are optimised for fast road use above track use, as such the spring rates and valving on the dampers are designed to be sympathetic for use on our rough roads. This is not the case with all coilovers!
