Don't bother with the 4gb 760. Get a 280X instead. I'd change the PSU, too: you cant get a better quality (albeit non-modular) SuperFlower for that kind of money. Do you need that Blu-Ray RW? And I'm not sure about the pre-installed custom water cooling.
YOUR BASKET
1 x Sapphire Radeon R9 280X Dual-X OC 3072MB GDDR5 PCI-Express Card with Battlefield 4 PC Game £251.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
Total : £321.58 (includes shipping : £8.00).
What is your budget?
£1500, eh?
YOUR BASKET
1 x Gainward GeForce GTX 780 Phantom GLH 3072MB GDDR5 PCI-Express Graphics Card £399.95
1 x Iiyama Prolite GB2773HS-GB1 144Hz 27" Widescreen LED 1MS Monitor - Black £259.99
1 x OcUK Tech Labs - BitFenix Ronin - 750 EX240 Watercooled Case £205.00
- 1 x Intel Bracket Fitted £0.00
- 1 x Mayhems X1 UV Green Premixed Watercooling Fluid 1L £7.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £169.99
1 x Gigabyte G1.Sniper Z87 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £119.99
1 x Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIG) - Green Light £79.99
1 x SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black £73.99
1 x Toshiba SSD HDTS212EZSTA 9.5mm 128GB Solid State Hard Drive - Retail £65.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £47.99
1 x BitFenix Alchemy Cable Bundle - Green £28.45
1 x Liteon DH-4O3S-04-B 4x BD-ROM (Black) - OEM £19.98
Total : £1,495.80 (includes shipping : £13.75).
Tip for you, get a Blu-ray player instead of a drive for your PC. If you have the space and whatnot anyway.
The software that's about atm is generally not very good.
