- 20 Nov 2013
Guys i currently have this ram and i would like to add another 4gb, please can you spec me some ram for £40 or under. thanks
You won't get 4gb of new DDR2 for under £40 at overclockers. Just Google 6400 DDR2, or look for some second hand stuff
does it have to be the same make of ram for it to work??
seems that your mobo suppor ddr3 it will be better if you get 4gb ddr3 as it will be faster and also it could be cheaper
his mobo:
http://www.gigabyte.com/products/product-page.aspx?pid=2551#ov
the shame its the speed(limited to 4gb and 1333MHz
so think about this:
4 gb ddr3 at 1333MHz under £40
or get another set of the same ram
http://www.overclockers.co.uk/showproduct.php?prodid=MY-058-GL&groupid=701&catid=8&subcat=144
Buy this ram and run it the lower speed.
YOUR BASKET
1 x TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34GM1600HC11DC01) £32.99
Total : £36.90 (includes shipping : £3.26).
In saying that it will default to lowest speed anyway!![]()
does that mean any ddr3 will work then??
