Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
As said before, my Pioneer VSX-2021 has died. This is particularly sad because it is a beast of an amp. Pic here compare to the Sony.
After a little research I really wanted a replacement before Christmas as I have a week and a half off work. I could wait for the January sales but I am willing to take convenience over any potential savings (which won't be much as the amp only got released in May/June) and it is only £450.
7.2, 8 HDMI outs, 2 HDMI in, Wifi, Bluetooth, Airplay, DLNA, 2 optical in, 4K Pass through, 3D, FM/AM Tuner, 165W Per Channel on paper.
8 HDMI inputs is great (7 at the back 1 at the front), although nobody really need all 8 but I have 5 plugged in at the moment so that leaves 2 spare which is saved for PS4 and or Xbox One.
So replacing the Pioneer with an amp that has an RRP that is 50% less would be a downgrade you think. In some respect this is true, and on that regard, I was going to get the Onyko 828 or the Pioneer LX57 but deep down only THX certification on the Onyko that i really want and the Pioneer is £1k at the moment and with what happened to the 2021, I think I will try something else this time round. The real left field choice would be a Marantz SR7007 but i couldn't find any in stock.
Step up the Sony DN1040. Someone I know bought one recently and he brought it to my attention, a little reading online to find it won What HiFi amp of the year and basically every review online is favourable, from highly recommended to award winning and at £450 it is also cheaper than the Onyko and the Pioneer.
First impression
LCD is smaller than the Pioneer, a lot smaller, it display about half the info the Pioneer had so at first I am confused what is connected and what isn't. The LCD doesn't display which speakers the amp is using for example. I got used to that with the Pioneer, it is a reassurance I know all 5.1 are being used.
But that is a minor point, once set up, calibrated (which is about 1 min work opposed to about 20 in the Pioneer), the amp is ready to go. Thankfully the onscreen (TV screen) menu is a lot better than the Pioneer. It looks like a PS3 menu, colourful, easy to navigate, it makes the Pioneer feel old and MS-DOS like.
Playing a movie, the sound field is vast and spacious (as commented also by my brother in law), good accuracy of placement of sounds, very detailed as I put on Breaking Down Part 2 on the background yesterday and heard something in the room, first I thought my iPad across the room made a sound but it turns out it was the soundtrack. This amp reveals layers of detail with great accuracy.
Music is also good, and from my 24 hours with the amp, everything sound as good as the Pioneer. The soundstage is detailed and all the placements can be picked out easily.
Airplay works as it should like a charm.
The amp also has built in WiFi so it makes connected up to your network easier if you don't have a router nearby. (note, when first connect the amp asked for an update which took about 20 mins)
Pro - Great sound, really great sound, mass of connectivity, easy of set up, great menu
Con - Small LCD, cluttered remote, no Spotify
Overall, I am really happy with this amp, and I think I would need to spend more than £1k to get something that sounds significantly and noticeably better.
First impression
