- 30 Nov 2011
All Tomy is saying is AMD and Intel get G-Sync in another form on compatible screens for no extra cost, while with Nvidia you get G-Sync on compatible screens that cost $150 more.
The good thing is Nvidia could adopt the same version AMD and Intel would be using if they wanted to.
Whats wrong with that?
we don't actually know if monitor manufacturers are going to try to sell their "freesync" monitor versions for more or less as none of them exist yet
in theory they should be even cheaper than the standard model as a freesync monitor will have a single port and no scaler hardware at all
we've also not seen production models side by side on gsync yet, so the cost is still debatable - the only "gsync" monitor on sale is a custom modified one so all we know is the cost that some retailers are charging for a modding service which is not the same thing
@greg
If that was aimed at me then that's bs.
@andy
I'm well aware what works on what, I only picked up on that particular quote as bru tends to be negative in anything AMD so I skipped the rest.
The physx part, can you point out out source where AMD specifically declined Nvidias offer and what the conditions were please, all I have ever seen is along the lines of Nvidia stating 'we are open to other vendors using PhysX' while actively going out their way blocking Physx on their own hardware when an AMD gpu is present in the system.
it is somewhere in the "gameworks usurps power" threadnought, though I'll be buggered if I can be bothered to go find it
