All the games are fully installed so the drive is only used for the initial disc check. Other than not swapping discs there is not really much advantage to download only games.
Do you drive a diesel at <12k miles a year too?![]()
I found it incredibly boring tbh!Don't Starve is definitely more of PC gamer's game.
Basically, you collect resources to build better items, and survive as long as possible. Definitely make a camp fire at night, otherwise your sanity meter (assuming it is the same as the PC version) will go down and you will essentially go crazy, and trees may start trying to eat you
There are some very amusing enemies, and eventually you will work through the different seasons (again if it is the same as PC), with Winter being the hardest to survive in.
Here is a quick review that may give you a better idea:
http://www.destructoid.com/even-without-plus-don-t-starve-is-worth-playing-on-ps4-268615.phtml
and there is some performance gains (even thought small) with going digital
As MOOGLEYS stated earlier, not this time round. All games that are on disc get installed to the HDD, so they're pretty much identical to the digital ones, it all runs off the HDD or SSD if you chose that etc. Unless there is a performance difference or gain I can't think of...
At least I wasn't the only one that found it boring.
I find that I have a massive performance gain from disc-based versions of games...
..in the time it takes to download the digital copy of Killzone, I could walk into town and buy it, come home and probably complete the campaign. Maybe even time to play some MP.
My internet is fairly slow, and Killzone Shadowfall is a 39.7GB!
Also, the prices of digital copies of games on the PS Store are horrendous! I remember new PS3 games being upwards of £50!!!
The fact that Angry Birds Star Wars is £32.99 says it all really..
Ahaha well there is that and I'm in somewhat the same situation, it'd take me a month to download KZ :| Although it does have that fancy play while it downloads thing going on... not seen it in action mind you!
Does that only work for certain games? I've downloaded several off the PS Store and I've never seen the option to play them while they're downloading :/
This is why I said it is more of PC gamer's game. There are many survival PC games that require you to gather resources, grind and generally work out how to do it yourself.
As MOOGLEYS stated earlier, not this time round. All games that are on disc get installed to the HDD, so they're pretty much identical to the digital ones, it all runs off the HDD or SSD if you chose that etc. Unless there is a performance difference or gain I can't think of... The only real benefit which you have already mentioned and I guess depends on person to person is the not needing to swap disc thing.
All games get installed to the HDD? Is it the full game or a cache system?
I was under the impression it was a cache system and not the full game, why did they decide to install the full game to hard drives? Wouldn't using both be far more efficient and make the console's potential even greater like they did with GTA V?
