If it a quality 450W even a 290 reference card might be fine to be fair. Playing BF4 with 2x290 Pro cards at stock (975/1250 - so small overclock from typical 290) and i pull 500-550W from the wall with my i7 at 4ghz.
I guess you never owned a small PC case that has high power Components in it then...id go with a 780 tbh. wouldn't go with stock anything.
290 is too long, 770 or 780 are the GPU's are will use.
Thanks everyone.
