Windows 8 trial
17 May 2013
West Sussex, UK
Right, thinking of trying Windows 8.1. What happens after the 90 days are up if I like it? Can I buy a key and continue to use it, or do I have to reinstall everything?
If you're talking about the 90-day trial version of Windows 8 Enterprise, no, you won't just be able to enter a purchased product key. It's a complete reinstall I'm afraid.
wut? Really? Why'd they do that? :confused:
At a guess, I'd imagine it's because they want to make all the Enterprise features available to companies for testing purposes, but there's no easy way of disabling the installed code by simply entering a lower version (Core, Pro) product key at a later date. I could be on completely the wrong track though.
If you want to test drive your chosen version of Win8 for up to 30 days and then enter a key without reinstalling, have a look at this.
Grab one of the 8.1 RTM ISOs and use a built-in serial.
RELEASE DATE: 08/21/2013
BUILD: 6.3.9600.16384.WINBLUE_RTM.130821-1623
FILE: Windows_8.1_EN-US_x64.ISO
SHA-1: BC2F7FF5C91C9F0F8676E39E703085C65072139B
MD5: F104B78019E86E74B149AE5E510F7BE9
FILE: Windows_8.1_EN-US_x86.ISO
SHA-1: 802CFCD3A411D99C097EA7E747F0B6697F9BDAC4
MD5: 7DD36FEA0D004ACFEDBDB3A5521EF5FF
Core: 334NH-RXG76-64THK-C7CKG-D3VPT
Pro: XHQ8N-C3MCJ-RQXB6-WCHYG-C9WKB
Thanks for the info. This doesn't look like an easy process :(
@KIA: What are those keys? Are they legal trial keys? Could you explain a little more?
Thanks
Right, I've just downloaded the Windows 8.1 download assistant thing from Microsoft site. The downloaded file is called WindowsSetupBox.
I tried both of those keys, they both work, but says it isn't connected to the internet? - I am.
Any ideas?
Any ideas?
u need to download the iso from somewhere else. not MS
Could you send me a link on here or via trust please. I've had a search and a number of different stuff is coming up, I just don't know if they are safe downloads. It'll take me about 4 hours to download, so don't want to waste my time/bandwidth.
Thanks!
They're placeholder keys. They can only be used for installation.
I'll send you links via trust.
You're downloading Windows 8.1 RTM. It'll nag you to activate every couple of hours.
Could you send me the links as well please. Malware invasion on my windows 7 set up at the moment, might as well reinstall a fresh windows temporarily to sort out the issue.
Thanks if you can help out.
