So I've exhausted all options on this and I need some expert help.
A few months ago I bought a load of new stuff from here to upgrade a family member from his old dual core S939 setup. The spec is below:
CPU- AMD A8-5600K FM2 3.6ghz
Mobo- ASRock FM2A75 Pro-4
HDD- Sandisk Pulse 128gb SSD
RAM- 8gb Crucial Ballistix Sport 1600mhz
PSU- Corsair 430w Modular
Case- Bitfenix Merc Alpha
Now initially I received a DOA mobo which OcUK swapped out for me with no issue, however I the one I received back also failed to display so I raised another RMA but the technicians got this to post fine and sent me the board back.
Work has been in the way over the last few weeks so I finally got around to trying it over the weekend and again I get no display. The fans spin up when the machine is turned on but there are no beeps errors and no LED's on the mobo are lit up.
I've tried just about everything I can from resetting the CMOS, trying different RAM and installing my old HD4670 instead of using the onboard but still nothing gets me a display.
Now given that the OcUK techies got this board to post fine, any advice on where I should be looking next?
