MSI 290/290X Gaming Edition Thread
Also, are you sure the Sapphire cards are guaranteed Hynix memory? As far as I know, the Sapphire card is just the standard reference PCB with a non-ref cooler slapped on it. On the reference cards, if I recall, it was a luck of the draw on the memory chips you got.
No vrm sensors does not mean anything. None of my Ice-Q's had vrm sensors and all of them overclocked superbly. However the Sapphire card still looks to be the pick of the 290 litter at the moment.
There is no guarantee, my Asus card which were all supposedly Hynix has Elpedia memory, but saying that it can clock upto 6600MHz on the memory.
Both of my peasantry VTX 290 Pro's at £280 a pop have no trouble reaching 1625 on the memory and mine both use Elpida. Its not the end of the world. :D
Hi, looking to replace my gigabyte wf3 7950 with a R290 custom cooled, cant seem to find review on this, also the is the Powercolor Radeon R9 290 PCS+ OC any good its out of the box at Core Speed: 1040MHz and Memory Speed: 5400Mhz
Thanks
Thanks
There aren't any reviews to my understanding. I've crawled Google and brought nothing back :(
With regards to the throttling issue, as long as I run the fans at 100% I can expect to be throttle free? No guessing what Im going to be using these for :D
Yep seems true.
Though Hynix generally is a little better, but at the same time good Elpedia will clock better than poor Hynix etc.
The MSI Lightning card I tested had Hynix, it did 7000MHz just on the memory OC, 6800Mhz was rock stable, so their dedicated power phase for memory definitely helps. :)
what does no vrm sensors mean for the average user not interested in overclocking?
yes, i would like to know that too..does it just mean we wont be able to overclock mental on the card but small overclock will be fine? and what temp will it start throttling? and whats a safe max temp 95c ?
