I did this a couple of weeks ago. I'm not sure what went wrong but it was flawless for me. My 7 upgrade was flawless tooYeah I did. 7 Pro to 8 Pro wouldn't carry my user profile across, 8 Pro to 8.1 Pro didn't carry over any installed programs..
Does not matter what they do,you'll always get people moaning about something,same will happen with Win9,10,11 etc..
Frankly I can't remember the last OS where some people did not moan about something with Windows and yes I remember the moaning about XP,Win7 etc...
Regardless I find it easy to adapt and move on,I'm ready for Win9,10 etc...
These Windows releases are becoming far too frequent. They are treating it like something you just reinstall and upgrade on a daily basis. The simple fact is, most people and businesses like a stable OS they can rely on and not have to upgrade it every couple of seconds.
I did this a couple of weeks ago. I'm not sure what went wrong but it was flawless for me. My 7 upgrade was flawless too![]()
If you can't handle the change and think its a pile of crap then you should not be using a computer or even leave your own house.
Can't decide yet between 95 or 98.
Pah, I still use DOS, Windows is just some junk you launch with a command, isn't it?
. Do miss the Win 95 days though. All Seriousness tho MS need to slow down abit!Pah, I still use DOS, Windows is just some junk you launch with a command, isn't it?
 .DOS good old days which was probably the last time I had to use my brain for some commands,Windows especially now you can do without even thinking unless you are one of those people that has an intelligence drop with the start button menu missing.
