Caporegime
- 1 Dec 2010
- Welling, London
I use wood, plastic, resin and metal (pewter).
Superglue is the adhesive of choice due to the ability to clean-break the bonded surfaces together. Polystyrene cement melts the plastic together, making for removing the parts (in rare occasions when you may need to) to be very damaging and messy.
For metal, you can use modelling putty that hardens through kneading it with an activation compound - usually combined with pinning the inner surfaces of the pieces together too.
Just to clarify, don't use superglue for wood if you may want to break the parts. You will just destroy everything
The best glue for wood modelling is undoubtedly Aliphatic wood glue.
