- 22 Mar 2009
VDSL2 IP Profile reset still required an engineer at the cabinet, isp cannot control it. Only the ADSL/ADSL2/ADSL2+ can reset by the isp.
Was told it'll be 24-48 hours. I also got 6 months refund as BT put me on the wrong thing
Currently 38/9 so we wait and see
Download speedachieved during the test was - 36.62 Mbps
For your connection, the acceptable range of speedsis 38.9 Mbps-48.63 Mbps .
Additional Information:
IP Profile for your line is - 48.63 Mbps
Upload speed achieved during the test was - 8.74Mbps
Upstream Rate IP profile on your line is - 20 Mbps
Well I woke this morning and it's changed.
Before it didn't even say my IP profile was 48.63 or 20.
I need to reboot the modem and my router.
The DSL/ADSL Checker says 48.63 is my lowest with 63.8 the highest on a clean line...can anyone explain what's going on.
Yeah the 48.63 figure given on the checker isn't your IP Profile its the sync speed between the modem and the cabinet, the IP Profile is a bit lower.
I guess you don't have access to the modem itself?
It may help you to reboot the modem first thing in the morning, see if you get a better result from that.
Well rang Plusnet myself this morning and they answered my questions.
They still have Openreach visit your home, fit the new VDSL faceplate and Openreach modem etc.
Then I should receive the Plusnet supplied router a few days prior ready to fit after the OR engineer does his part.
Engineer just makes sure the BTO modem works, up to you to connect the router to it.
Or at least was implying.
