Images of items I have purchased.
Status
Not open for further replies.
New PC with everything bought from OcUK
Cosmos 2 by jjohnson2012, on Flickr
Case is BIG
PC by jjohnson2012, on Flickr
Components are as follows:
4770k under a corsair H100i
Asus formula Z78 mobo
Geil EVO 16gb RAM (2400mhz white)
2x EVGA 780 ti superclocks with an EVGA sli bridge (which is now the right way up!)
500gb samsung ssd
3tb seagate hdd
Pioneer blu ray
Superflower 1000w gold rated PSU.
I need to swap out the 6 pin extension cable for a white one though as they sent me a black one in error, but its okay :P
Also bought an iyamma 27inch 1440p monitor, logitech 710 mechanical keyboard (its lush) and logitech G500s mouse!
/expensive month
Finally got the lid painted
That's a helmet right?
Liking the ocuk decal :D
Lovely looking system James J. 780ti's in SLI you mad man :D
Is it just me though, or is one stick of ram not clicked in properly? the white tab at the top seems to be open a little is all :)
Ordered some paracord and heatshrink :) Going to sleeve my MX 365's ... Fed up of them tangling. May also make some cords if i can find the 3.5mm plugs and some suitable cable online.
Best go cut up a cheap set of headphones to have a play with to make sure i can get them back together haha
It is now, noticed it myself after I took the pick. It worked without issue though, just seemed to pop out lol. I've tidied up the cabling as well as it was a bit sloppy.
As for the ti's, YOLO and all that rubbish :D
Status
