Hi Guys
EVGA are supporting a 10 day promotion with us against the pricing of the Hadron Air case.
This is a supported price from EVGA meaning we will not be able to hit a crazy price point like this again.
If you were thinking about grabbing one, now is the time.
EVGA Hadron Air Mini-ITX Case - including 500W Gold Power Supply - Black @ £149.99 inc VAT
Now you are able to build a mini ITX system with enthusiast performance! The EVGA Hadron mini ITX chassis was designed to not make any compromises. At a mere 305mm height and 169mm width, the EVGA Hadron chassis is extremely small, but capable of holding today's latest hardware.
With an included 500W Gold rated power supply, support for a full sized graphics card, sleek looks and enthusiast features, the EVGA Hadron mini ITX chassis packs a serious punch.
Features:-
- Sleek look, extremely compact size!
- Mini ITX Form Factor
- Integrated 500W Gold Rated Power Supply w/ 40A on +12V Rail
- Supports most full size enthusiast graphics cards! (Up to 267mm, double slot)
- 2 x 2.5/3.5in Drive Bays
- Supports slim slot load optical drive
- 2 x USB 3.0 Ports
- HD Audio In/Out
- 2 x 120mm Exhaust Fans
- 3 Year Warranty
Specification:-
- Color: Black
- Form Factor: Mini-ITX
- Power supply: 1x integrated
- Expansion Slots: 2
Total fan possible:
- 2x 120mm (cover)
Thereof pre-installed:
- 2x 120mm (cover)
Drive Bays:
- 1x 5.25-inch slimline slot-in (external)
- 2 x 3.5 / 2.5 inch (internal)
I / O Panel:
- 2x USB 3.0 (internal connector)
- 1x each Audio In / Out
- Maximum video card length: 267 mm
- Dimensions: 169 x 305 x 308 mm (W x H x D)
- Material: Steel
- Weight: 6 kg
Power Supply:
- Efficiency: 80 Plus Gold certification
- Power: 500W
- +3.3 V: 20 A
- +5 V: 20A
- +3.3 V & +5 V: 130W
- +12 V: 480 W / 40 A
- -12V: 6 W / 0.5 A
- +5 Vsb: 17.5 W / 3.5 A
Was £179.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Features:-
- 2 x USB 3.0 Ports
- HD Audio In/Out
- 3 Year Warranty
Specification:-
- Color: Black
Total fan possible:
- 2x 120mm (cover)
- 2x 120mm (cover)
Drive Bays:
I / O Panel:
- Material: Steel
- Weight: 6 kg
Power Supply:
- Power: 500W
- +3.3 V: 20 A
- +5 V: 20A
- -12V: 6 W / 0.5 A
ORDER NOW
