It might have been this Rusty if not what do you guys think
3-5-2
Cavani, Ibra
Hazard, Toure Yoyo, suarez, IF Fernandinio, Lucas
Kompany, Luiz, Silva
Cech
Suarez won't be on max chemistry with that hence why we used Gerrard instead of Fernandinho before. To be honest, Gerrard is a pretty good CDM (in a 2 CDM formation).
You'll get pulled to pieces defensively with that - most 352s do. They're good for attacking but against a semi-competent player with either a 4231 or 442 or 433 combination you're going to have your CBs getting mullered down the outside. They'll get pulled wide and then you'll get overloaded in the middle unless your CDMs are all the way back.
All formations have negatives but I couldn't personally use 352 as a default formation.
Try 442. It's surprisingly strong for me.
