FIFA 14
Status
Not open for further replies.
I probably should've said what my current side is as well in case I already have any players that might be suggested.
Handanovic, Radu, Chiellini, Benatia, Konko, Vidal, De Rossi, Hamsik, El Shaarawy, Candreva, Balotelli.
SIF Benatia is one of the best CB's in the game, IF Balo is awesome, very strong and a great shot, same with IF Tevez, maybe get IF Vidal in there when he drops in price.
Is IF Balotelli much different to his NIF at the end of the day?
SIF Benatia is ridiculous, I agree :)
I would try something like this:
*Eredivise pic*
I prefer Veltman and Denswil as my CBs and I've used Daley Blind quite a lot at left back in the past even though he has shocking pace and high attacking workrates he's a decent player. You could try Hoesen as a striker if you want somebody with slightly more pace but Sigthorsson is actually pretty good. If you want to swap the CAM for a CDM then I would put Enoh in there instead of Piazon, there aren't many good defensive midfielders in the Eredivisie though. :)
I'll have a look at them, cheers, might try and find a good Silver GK and a B team!
are Fabregas and Hernanes anygood as the middle in 4231 or 41212..
made a basic 442 team and it's plays ok, switching it to 41212 also seemed to work well with modric at cam..
D.Costa is good at holding the ball up, but he's just so clumsy!
anyone who has played 442 and 41212 for decent amount of games have any opinions on which is the better formation? I am messing about with 4231 with cam and wingers.
just need to settle on a formation or two, lol
SIF Dos Santos looks great but not easy to hybrid in team including TOTY Silva and NIF Ramos
SIF Santos is 81 rated as a ST and 84 as a CAM
That's why I will probably end up trying him out as a wide cam tomorrow.
His 84 passing or whatever it is, will be wasted up top unless you use him to play in overlappers who 1-2 with him
Typical Rybo match 41 shots, 34 on target, possession 58%.
Still lost 3-1. He had 5 shots, 3 on target.
Really need to sort out my shooting. 80% of the time i am winning up until 80mins and then my players just turn into spastics.
My team at the moment:
Any flaws you can spot straight away?
Diego Costa has 78 in 121 for me but he's played up front by himself. Luis Gustavo is an excellent cm/CDM.
IF Melo and IF 81 Maicon are excellent.
As a cheap last 20 min striker try Bernard for the Ukranian league. Very quick and only 5 foot 4.
Guarin > hamsik
Or try marchisio there
Other than that your team is perfect you might as well save up for if benatia then sif benatia
St is a personal preference between Ibarbo, vucinic, Gomez, tevez, balotelli and if milito
They are all good
Guarin > hamsik
They are all good
Thanks, i'll give Guarin and SIF Benatia a try. What backups would you suggest as a fitness squad?
You looking for people to rotate or a full squad from a different league?
I would go for another team and rotate between matches.
----- jovetic
Nasri - fernandinho - ramires
Garcia - Gustavo/ if melo
Enrique - Ramos - if Miranda - Mariano
Courtois
Is the team I would go for to rotate with
You could change it to LM and RM version and stick Sandro in the rcdm position to suit any bpl RM and LM. Then use fernandinho or nasri at cam
----- jovetic
Courtois
If the quality is good enough I was thinking of just rotating. I've got a BPL team already but I much prefer my Serie A side.
Some of my investments are shooting up in price others not so much.
SIF dos Santos and SIF matuidi are on the rise especially Santos.
SIF Maicon, SIF rakitic and IF melo only gone up by a couple of K.
Santos has increased by 10k in 2 days.
should have bought more I have around 6 iirc. Bought a load of maicons because he's Brazilian and I think alves being cheap is hurting his increase
Status
