What r u confused about?
getting the swash plate level and setting the pitch, always getting one servo that is out
Can anyone assist me?
I have a Walkera 22E (35mhz) and the transmitter has died, I am having trouble finding a replacement. Everything seems to be 2.4ghz Digital now and I don't think it's easy to convert it?
Can some one point me in the direction of a suitable replacement TX?
Also remember that the servo horns are sided.
if it doesn't work one way, turn it round and put it on again.
Perhaps sided isn't the right word.
The way the teeth on the servo and the horn line up with the teeth on the horn isn't normally even when the servo is centered. So if the arm sticks out at 90 degrees if you pull it off, turn it round so the left arm is where the right arm was and put it back on again it you probably wont be able to put it back at 90 degrees.
I've noticed it on most servos although it's harder to see on ones with finer teeth.
Get it as close as you can physically then you use the sub trim setting in your transmitter to correct this.
Flybarless controllers also are capable of correcting this mis-alignment.
I think the Walkeras have a weird PCM so you can't just use any old 35mhz transmitter.
You'll have to search for one, or go to a 2.4ghz system by replacing the 4in1 as well.
You can buy 4in1's and transmitters as long as they fit it will be fine.
Well i decided to get into flying heli's after playing around with a 3ch heli i decided to order the honeybee v2 since i heard its a great heli to train on anyone else have any exp on these helis? tips?
Really want to get into 3d flying at some point was going to order a 6chan but a lot of forums around seem to be against it for 1st time flyers etc.
