What kit was it Gilly?
Some beers can take a little bit of time to smooth out, but there could have been either some cleaning chemical residue left, or a problem during fermentation. I know it's difficult to say exactly, but how would you describe the "chemical" taste?
John Palmers How to Brew has some good information on common off tastes on beers and probable causes...
http://www.howtobrew.com/section4/chapter21-2.html
But don't be put off. Even if it has gone horrifically pear shaped, don't worry, just think of it as a learning/practice brew. Then nip down to Wilkos and pick up a Woodfordes Wherry kit as they're on offer at £15ish (or they were last weekend) which is an always reliable great premium kit.
Duly noted! Thanks dude.For last Wherry I made I swapped out the kit yeast for S-04 and it improved it immensely!
Tell ya what trust us your address we will send you a bottle across of wherry to compare.It was the Woodford's Wherry kit I used.
Not sure on the taste, I can't describe it. It's not a medicinal thing, I'd say it's a bit sharp and bitter when a hard aftertaste.
It was percarbonate I used for treating the equipment - came from Wilko's in a pack.
Did that yeast make the sediment compact in the bottles/barrel? This is my only complaint about the Wherry, that the sediment is so easily disturbed, even after 6 months in the bottles.
Drew some over the weekend, it's been over two weeks now. Very cloudy, tastes like ass
Wow, thanks very much![]()
Is it worth trying finings and bottling, or just accepting that I've wasted a month?
