Check your junk!
Hope all goes well and you just get a hot female feeling up your bits and a "Don't worry, there's nothing wrong down there".
I found a lump on my left one last year - scared the living hell out of me, turned out to be a harmless cyst,
The doctor told me the ones on the epididymis (at the top) or on the tubes aren't normally ones to worry about, but if you ever find a lump down there - the golden rule is to get it checked.
I'm sure it'll be fine,
Been there done that, I was about 27 years old and it came from nowhere. Obviously embarrassing going to the GP and getting it felt up. He then sent me to the local clinic where a nice nurse scanned my bits with an ultra sound probe (exact same one they use on pregnant women). Turns out it was nothing, it's still there 3 years on.
Have you named it?
Had the same happen last year.
Went to Docs and he sent me for an ultrasound.
Turned out to just be a cyst so hopefully just the same for you.
Best of luck.
Happened to me, Turned out bad but caught it early. Had surgery and was all good.. Best of luck OP if youve found it early you be all good in no time
Good luck and keep us posted. I had it in 2011 and had surgery to remove it and also needed radiotherapy on the other side. I posted about it at the time so there's probably a lot of info in my thread below. But if the doctor suspects it to be abnormal then the next step is an ultrasound scan.
http://forums.overclockers.co.uk/showthread.php?t=18325829&highlight=testicular+startername_hades
Happy to answer any questions over pm. But the main thing is not to panic as if it's serious then it's actually very treatable.
Thanks for the offer :) I'll see how my appointment goes this afternoon!
Good luck main thing is not to worry and go to the docs.
I've had some trouble with the waterworks and a course of tablets healed me up nicely huge relief when he said it wasn't cancer though but sitting at home worrying about it won't get it sorted.
