My computer has been working fine since I first built it, all of a sudden I am getting random crash's, the computer does not blue-screen it just freezes forcing me to manually restart the computer.
I have literally no idea what could be doing this, at first I thought it was my copy of windows so I re-installed with another copy I had, it's been working fine for day's and now all of a sudden the same problem arises.
Computer Specifications
Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
8.00GB RAM
Gainward GTX 780
Windows 7 Home Premium
Attempted Fix's
- Freshly installed Windows 7
Now I have no idea where to start, you guy's were very helpful in helping me build/purchase my PC, so I can only think you know what your talking about.
Event Viewer Logs
I am positive this is what the problem is, as it matches the time/date of the crash's exactly on two separate occasions.
8.00GB RAM
Gainward GTX 780
Attempted Fix's
Event Viewer Logs
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2014-01-24T17:12:46.904002500Z" />
<EventRecordID>6302</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Jayke-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
		- <System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
- <EventData>
</EventData>
</Event>
