- 21 Jul 2005
- Officially least sunny location -Ronskistats
Guuuuys, started OC'ing my 8320 today and so far i've got here....
4.8 (24x200) with 1.4v, socket temp 48.1c, core temps 38c after 4hours priming.
I've not yet messed with anything besides LLC (set to UHIGH) the multi the cpu and ram volts and the ram timings.
I also quickly tested 220x23 and that was stable with 1.428v,
I tried 220x24 but that needed 1.486v and got a lot warmer (57c socket, 48c core)
Welcome and good news that BT!
At what point does the core temp tell the truth? (it did read it was over a certain c but can't find it now) I assume im best still going by socket temp? and is 1.5v the max I could safely use day to day? getting to this point was very easy (like OCing an intel tbh)
Spec is... 8320, sabertooth 990fx r2.0, 8gb crappy kingston 1600mhz, my custom car radiator loop.
I was told the package temp was the one to watch but I feel the software is incredibly innacurate in the lower scale (20-40c). 1.5v is the most I would push on air, sounds like you got a good clocker there!
I would push it to see how far you get then back off voltages till you get stable and drop it a notch for 24/7 use.
Mines at 4.7Ghz and the temps are good.
with 1.48v, it was prime stable for around 60mins then threw up an error on core6, i think thats probably stable enough for me as I doubt i'll ever stress it that much gaming (when i should be working)
