Pokemon X and Y - 3DS - Oct 2013
How long am I looking at playing before I beat the Elite Four? Assuming I just keep the 6 Pokémon I currently have, only level and only use them and not spending a lot of time grinding XP/searching for specific pokemon. I'm currently 4 hours in and only just defeated the second gym!
Ok, i've just added you, is bagonmence any good?
I think so! Especially with sheer force! I think you tried to trade with me but I didn't realise it was you!
with the right training and some dedication your bagon could one day become:
Great!
How do you get it like that though, I know there is the Training and the IV stuff but I dont understand it all..
So If I go into that Super Training how does that make your Pokemon stronger?
I understand they all have
Attack
Defence
Speed
Sp Defence
Sp Attack.
With numbers attached to each one which go up as your pokemon level up so using the Super Training boots those stats?what does the punching bag do?
I just did a test with Super Training and did the Sp Attack which should give me +4 however I started with 19 Sp Attack and even after passing its still 19..?
Hi that's correct. So at where you're up to super training is probably the best way for you to train right now.
With bagon , this is a MixMence I.e it hits hard on the Attack and Special Attack stat. Mainly attack but with Hydro Pump or Flamethrower/ fire blast to give you special coverage against steel pokemon or grass or fire.
So ypu want to super train bagon to have full Attack, full speed and the remaining 6 eV into HP.
dragon dance is his codegrais. His dragon dance raises his speed and Attack go up hy 50% each in a battle where you use that move. If he ko someone, his attack gets another 50% boost. (MOXIE) ability.
in my pic salamence has hydro and fire blast but realistically you'd never run both. Use one , earth quake and dragonclaw as his primary moves
mine doesn't have the Moxie ability though, it has Sheer Force and is Naive Natured.... I think these 2 points have such a big impact on what they will turn out like. Even If I got mine to level 50 like yours I think it still wouldnt be as good?
I have also tried to do the Super Training attack which gets me +8 to attack however when I go back out and check the stats it doesnt give me +8... it stays the same.
Hi James, sheer force becomes MOXIE when it evolves later on.
Naive means bagon you got is a s speed get a 10% boost and special defence minus 10%. the bagon you have is perfect in every respect except Special defence in terms of IVs. So if you trained yours like I said full Attack, full Speed then yours would be exactly like mine, except Spec Defence will like be 80 ish rather than 90.
Ok I am a total Newblet can you give me exact training steps I need to do?
Go to Super Training and complete all of the training to get up to level 3?
Then just keep doing the Attack training over and over?
And also do the Attack L punching bags?
asically the mini games in training put the EV up that you train in. I.e if you do attack mini game your attack goes up you would also earn an attack bag that you can hit to again increase attack.
you can put 252 ev maximum into a single stat and 510 in total. So you'd want to max out 252 in attack, 252 speed and 6 in either hp or special attack.
When that stat is maxed out the game wont let you attack any more bags in that stat.
Don't use medium or small bags just discard them and only use large backs.
The actual stats won't increase there and then, but when you level up you'll see bigger increase in the stat you ev trained!
Shelgon away!
read this guide
http://uk.ign.com/wikis/pokemon-x-y/How_to_EV_Train_Competitive_Pokemon
Finally got around to picking up a 3ds and as I have always enjoyed pokemon since the original blue I couldn't go without.
Got Pokémon X
GTanny 1435-5398-4443 :)
Great thanks, I have trained that Bagon to have max attack and speed, just need to get it to level 50+ now
Bagon will be a bit fragile. If he takes an icebeam to the face he'll die in one shot. Known as a OHKO. Same with a dazzling gleam. But get him set up and let him use dragon claw (tm and levelling move) and earthquake with dragon dance and either hydropump or flame thrower / fire blast as a special move to kill Steel type pokemon and also grass type. Use earthquake against everyone else that doesn't fly and dragon claw against other dragons and flying pokes that aren't fairies.
