- 23 Jan 2014
Hello! It would be most kind if you could look at my second build and provide advice. Thank you very much.
CPU - Intel Core i5-4670K
CPU Cooler - Alpenföhn Gotthard
Motherboard - Gigabyte GA-Z87-D3HP
GPU - Sapphire Radeon R9 290X Tri-X OC, 4GB GDDR5
RAM - 2 x Crucial Ballistix Sports XT DIMM kit 8GB, DDR3-1866
PSU - Fractal Design Newton R3 800W
Case - Nanoxia Deep Silence 6 Dark Black Window
I intend to use the 2 HDDs, 1 SSD, and the operating system from my first build, and I have already bought the RAM as well. The items I feel iffy about are the motherboard and the PSU. Is there a better motherboard I could buy for a similar price? I don't think I will ever go for Nvidia SLI or AMD CrossFire but it doesn't hurt to have the option. Is the PSU wattage adequate? I was thinking that if I ever get another one of those GPUs, that will only leave 300 watts for the remainder of the system. That doesn't sound like enough!
So, what do you guys say?
