I've gone from 13.11 Beta9.5 to 14.1 to 13.12 Official..
13.11 Beta ran fine for me even on Ultra. 14.1 turned out to be a complete mess (yes i did uninstall previous drivers in the correct way etc etc).
First off with 14.1 it crashes when i hit the options menu.. found out it was the Intel graphics i had to disable but even then its a stuttery mess with frequent low dips to 30. Cant run Fraps or Afterburners OSD and i hear OBS wont even stream as a 'game' option.
So i go onto 13.12 Ofiicial and it all seems fine again.. until i hit the options menu in BF4 and hey.. it crashes again. So i disable Intel graphics so i can set my settings to how i want them and enable Intel again.
Thing is no way am i disabling my Intel HD 3000 graphics as i use this for my third monitor which i have for monitoring stuff or watching TV etc. And since just last week im now running my second monitor from my motherboard aswell as the third. Monitor one is for gaming anyway.
You'd think Mantle would actually be able to run with Intels graphics but its pretty obvious they're shunning opposition here. Lets hope they dont keep it this way but what a way to start Mantle. They should have waited longer in my opinion and had some of these things sorted out but im guessing EA might be behind all this. They usually rush everything.
I know its a Beta driver but ffs i spent hours of wasted time trying to figure out why the 14.1 Mantle driver wasnt working good for me.
At least put something like 'you will need to disable your Intel graphics and even then it may be a stuttery mess' on the bloody driver page/release notes.
Rant over.
Rant over.
Run in normal mode and it will ask you to restart into safe mode.
