- 1 Jul 2007
Let us know the outcome, as said never paid attention to the description, just the selection menu. I'm planning on trying them too.
Can anyone recommend an LED bulb with some decent wallop and a wide viewing angle for my outside light?
It's a PIR lantern so it needs to be something that is up to speed immediately - I've tried an energy saver in it and I may as well not bother having the light at all.
Normal filament bulbs don't last very long in it as they are frail and it gets knocked easily where it is.
E27 fitting.
Are they pendants with shades or can you see the lamp? Because there are some very good quality integrated compact fluorescent lamps with nice colour temperatures, no flicker and instant start that are half to a third the price of decent LEDs.
I'm putting 8 spot lights in my kitchen/lounge so obviously will be going led. I need some gu10 fittings and bulb recommendations, just nice white fittings nothing that will stand out. Also nothing that glares to much because there won't be any other pendants in the room so when on must spread light nicely.
I'm going to be using a lightwave dimmer so they need to be suitable for this.
Only advice I've had so far are to purchase jcc fittings and bulbs separately.
They will be GU5.3 MR16s. They are low voltage Halogens, whereas GU10s are mains voltage halogens.
It will, unfortunately, make finding a good quality LED option a bit harder.
Lets give a try.
You have 12 led lamps at 5 watts, so 12x5= 60, (60 watts),so to run those led lamps you would require a 60va (volt amps) transformer.
<snip>
A room has 4 downlights using 50w Halogen bulbs each has its own transformer all rated at 60VA. You could successfully replace the Halogens with the Crompton 5w LED MR16 which gives out light equivalent to the 50w Halogen bulb. So to summarise - Total equivalent wattage equals transformer rating required.
That doesn't fit with this:
