£1500 build :)
5 Jun 2007
extremes.spacious.indelible
Hey guys,
I'm looking at building a new PC in May/June (obviously a lot can change till then I know).
But was just after a spec as I've been out of the game for at least 2/3 years now so want to start getting up to speed with things :)
Have around £1500 (give or take a few hundred, want best bang for buck obviously) for a PC and monitor.
Also is there any new technologies coming out that'll change things massively between now and summer?
Is this just a gaming PC or will you use it for Heavy video editing or CAD?
Do you need an OS?
Are you interested in a colour themed build?
Are you likely to upgrade as you go?.. (Add another GPU for SLI/Xfire)
Sorry meant to include more info but forgot :(
Main priority will be gaming, but want to record and edit said gaming to put onto a YouTube channel, so some video editing yes.
I'm not into LEDs and stuff these days so just a nice sleek black case :)
Also another thing would love this to be as quiet as possible, so don't mind spending money on good quality cooling :)
:p
Are you sure that K2 cooler will fit in the 330R?
If Kitguru are worth their ilk, id do.
CPU coolers up to 170mm-tall can fit in the 330R without problems. It is possible to squeeze a unit a few millimetres larger than the 170mm limit into the chassis, but interference with the side panel’s foam may occur.
K2 is 165mm ish..
Epic stuff so far guys!
Would upping the budget to 2k make a huge difference performance wise, or would you say its a waste of money?
Would love dual 27"monitors :D (Even thought i currently live in Australia and have NO idea where ill find space in my parents house for them when I get back :p)
That case is very nice, you're unleashing the inner 15 year old in me :p
Also, don't need an OS :)
If anyone could spec me a Red/Black colour scheme with that case + fans and cables for 2k, I would forever be in their debt :p SLI and another monitor maybe?
What happened to wanting a plain black case ? :D
