Of course it will.![]()
I assume your speculating again?
I've tried to keep out of the thread as it seems you can't say anything negative about Mantle without people quoting 'Beta' at you over and over. As the fact the 7xxx series was not going to be supported/fully optimised was announced 3? days before the driver was released as a user who bought BF4 on release I was quite eager to get my hands on it to much disappointment, I don't really care if its AMD or DICE, they're supposed to be working together so the blame lays on both of them however Mantles known issues are pretty massive and more akin to an Alpha.
I've come to the conclusion people are easily pleased! It wasn't a 'free' performance boost for me as I bought AMD cards for BF4 when upgrading due to the prospect of Mantle. And if the final version is not going to be out until the end of the year when DICE are well into making their next game it just seems plain wrong to me to advertise BF4/Mantle unless it was advertised as BF4/Mantle Beta - most cards not supported correctly for the first 4 months of the games release at least? and I just missed it?
Shows what damage keeping a 4770k will do at stock tbh, would prefer these results with a healthy cpu clock, I'm near matching those mantle frame rates with an underclocked 780.
I know I know mantle is all about taking strain from the cpu away, but why on earth someone would buy a k or x chip and run it stock in a high end title is beyond me.
I'm half tempted to get BF4 just so I can benchlol
Does FRAPS work in BF4 yet?
Works fine for DX, does not work with Mantle.
I just gave it a go. BF4 stops responding if FRAPS is open![]()
Shut down afterburner/precision x overlay first. I believe fraps interferes. If it still doesn't work might be a Nvidia issue as it works ok for AMD under DX only. Mantle it crashes the game.
Cheers, that seems to have solved that problem. Now I get "Game disconnected: client closed down connection."
I remember now why I stopped playing this game![]()
But why on earth someone would buy a k or x chip and run it stock in a high end title is beyond me.
Guilty
Could well be the queueing bug.
Try to join a server that has no one in the que and had slots free.![]()
Since they patched it around a month ago I've had so much trouble joining servers.
Had this issue even on servers with plenty of free slots. Found this fix on another forum. Open the following ports for your router.Could well be the queueing bug.
You're dreaming if you think a cpu overclock will narrow the difference between mantle and dx11 mate. I added a 18% overclock to single player in DX and it added 3.5% more fps. You'd expect more in multiplayer for sure, but it won't be near 37% i can promise you that. These are single card fps remember. Any overclock you add to DX, will also effect Mantle. Maybe not as much, but it will increase mantle fps.
BF4 has started to crash with this driver, was fine before![]()
Almost identical to what i last got on shanghai. i7 4770k @4.5ghz, ram @2600mhz 1T, gtx 780 boosting to 1097mhz at stock. Ill do another as the last run was pre last weeks patch. Game runs so much better after it.Their testing must be a little skewed or something in that case, Shanghai, 64 player (at least 95% populated) 1920x1080 full ultra with 4770K at 4.6ghz Single GTX780 @ 1006/6000 around 15 mins testing:
Frames, Time (ms), Min, Max, Avg
77770, 904468, 58, 113, 85.984
If I get chance I will re run with CPU at stock and see what differences I get.
