Windows Server 2012 R2 Essentials as a desktop OS?
Caporegime
19 May 2004
Nordfriesland, Germany
I was given a MacBook Pro when I started my PhD but, frankly, it'd be a lot more useful if I could install Windows on it (bootcamp, obviously). Windows Server 2012 R2 Essentials is available as a free download for students so I wondered whether anyone has tried using Windows Server 2012 as their desktop OS? If so, does it work okay?
are you really saying that's the only option? :confused: surely they must offer a normal client OS like 7/8/8.1?? i really can't see the point in tinkering around with a server OS unless you're really very interested in the features they offer. if you were, you wouldn't even be asking.
Nope. If I want them I have to pay; and free is good :D
Well, the point is that it's free. Windows Server used to be okay as a desktop OS once you'd fiddled with the options a bit, I don't know whether that is still the case.
I've realised it's actually the Standard or Datacentre editions not the essentials; it just has the image from essentials on it! Mind you, I don't think the difference would matter for me.
A lot of academic institutions have access to Dreamspark, Microsoft's academic licensing. Ask your sys admin if they have it, you should be able to get various o/s versions from that.
Unfortunately my uni only pays for the full Dreamspark that includes the desktop OS's for the Computer Science department so I can get the stuff that is free to all students (i.e. Windows Server and Visual Studio) but not some of the better stuff.
Well, the installation went smoothly enough - once I'd figured out how to get the Mac to burn a bootable DVD from an .iso - but using Windows Server is proving somewhat problematic. The big free antivirus software programs all refuse to install on it - it took me about an hour and a half to figure out a way to get Avast installed but I think now I've got it going it should all be okay. There are a few niggles like the fact I can't figure out how to add 'Sleep' to the menu of shutdown options (but hitting the power button will put it to sleep so it's not a big problem) and I can't persuade it to update to the latest graphics drivers since they're refusing to play nicely with Windows Server 2012 despite the fact that the underlying core is identical to Windows 8 so it should be completely compatible.
I thought this might be the problem you have, many program installers designed for XP/7/8 will not allow you to install onto a server OS (purely because of hard coded installation requirements). You will probably find this sort of thing all the time.
Could just chip off antivirus? I have never bothered with any and have never had an issue in the past 15 years...
As for the graphic drivers, you might be able to point the windows driver updater to the extracted drivers folder and let it update manually perhaps. You may well find that quite a lot of games wont install to server 2012 too though.
I got the antivirus running okay. It just took a bit of effort.
It runs games fine; the same game runs noticeably better in Windows mode than on the same hardware running Mac OS. I'm guessing that's due to porting issues more than underlying performance but it's still pleasing. I'm still working on getting the latest drivers to play ball and install but it's working perfectly well as a desktop OS.
And I solved the driver issue too. It turns out Intel do two downloads of their drivers; one as an .exe for "end users"; the other as a .zip for "IT professionals". The .exe checks the OS version and throws a wobbler but the .zip version will install just fine.
I used Server 2003 on a desktop machine years back as an alternative to XP. Didn't have any major issues with it, even games worked ok.
Can't you just buy Windows 7/8? Surely the small amount of money it will cost will be worth it in terms of productivity.
*shrug* It's not that cheap on a PhD stipend and there's actually very little difference once you've tweaked it into shape.
I have tried server 2012 as a desktop OS for a bit. It's ok, but once you turn off the server focused bits you basically just have windows 8. Unless you have something that specificly needs it I wouldn't bother.
Should be fine. One thing I found was wireless connectivity isn't an installed role by default.
This is true: the http://www.win2012workstation.com/ link marc2003 posted above explains how to fix it and most (but not quite all) other things though. The wireless lack is particularly painful, though, for obvious reasons so make sure you have a second device handy.
