Images of items I have purchased.
Status
Not open for further replies.
End result
Some of your food's food appears to have somehow gotten on your plate :p
We've had this about a week and it's been brilliant. Over the course of a week we can usually expect to get somewhere between 10-20 nuisance calls from Indian call centres and the like. Since installing it we've had just two, both of which we blocked from ever ringing again. No nuisance call has gotten through in the last 2 days. Fingers crossed it stays that way.
How'r you coming along? I've gotten back into guitar recently, been attempting some ragtime, is tough!
Good I think, I am doing a mix of Rocksmith's lessons with Justin's Guitar course. In between I am just practicing chords changes from E, D, C, G & A. Sometimes I just sit on the sofa changing chords.
I have notice I can tell the difference between the neck of my T5 and GS Mini, I couldn't a week ago, didn't appreciate it but now I do and it is quite obvious. I also can tell the difference in the action between the 2, the T5 is much lower. So I think I am making progress.
I only bought the Capo because I want to learn Wonderwall and it requires it.
I'm the same don't ever use one and been playing for about 15 years ( though hardly ever over the last few)- to be fair if you're just learning and want to be able to play along with the original easily it'll be worthwhile as a confidence booster
Only if you want to do it in the key of the original.
43 years gigging in bands and I've never owned one.
I guess it's like people start learning photography and they seem to get all kinds of filters. (I've never used them up until last summer, only decided to get one after all these years)
That and Rocksmith on the Xbox requires it. When you start the game you go through a tuning page to make sure your guitar is in tune. If you try to learn a song other than E-standard it will go to the tuning page and tune the guitar to that. For Wonderwall it ask you to put on a capo after tuning it to E-standard. So in order to even get to start learning the song, I needed to put on the capo.
I must admit I do own one even though I don't need it, sometimes you just get that open string sound you can't get when using other chord forms. I suppose it's like riding a bike with one stabiliser :D
I use mine all the time because, being a baritone, I'm more comfortable in different ranges, which are not those based around E standard tuning.
Tune the guitar after putting the capo on.. If you do it before, you'll just have to tune it twice as the capo tends to change the tuning a little bit.
You do, you tune it when you load the game up, then it ask you to put the capo on if the song requires it.
It the song requires it other than E-standard, it will tune it to that too.
Status
