Unless you only play a limited selection of games, you've already got a bottleneck.
Even if you overclock your FX83, with another R9 290 you're going to have a bottleneck.
No AMD CPU is up to the task of these extreme GPU set ups, and I wish people would stop running them and diving headfirst into the sand of ignorance![]()
Not you again, you really are an intel preacher.
What is your 3dmark firestrike graphics score running your 290Xs @stock.
can we have some more opinions on this please guys, because a lot of people do run xfire sli with 8320/8350's
Would there really be any difference with firestrike?
A lot of people aren't bothered about benches, if they see an increase in performance upgrading to 2 gpu's regardless of cpu I think a lot of people would be happy.
Using just the graphics score you can compare with an intel setup to see if there is a bottleneck.
The reason I said firestrike and not the extreme version is because of the high fps which will highlight a bottleneck.
Using a bench is the proper way to test for a bottleneck.
If someone with a 8350 and a couple of 290Xs want to run stock clocks on their cards using firestrike, I will do the same with two of my 290Xs and an intel CPU.
i got an [email protected] and it does bottleneck even 1 R9-290X.Most of the time in games which not using all cores(so most of them).IPC of amd chips sucks.Get a 4770K and done with it.Im going to do the same too.
Isn't that firestrike extreme?
No that's standard firestrike. I don't have one of firestrike extreme (with stock gpu clocks) but i can do one if required.
