xfire msi 290 oc with 8350
Ideally just needs to bench some games against LTMatt, none of this Firestrike rubbish :p
You have Avenged and Ras both stating bottlenecks in games with a single R9 290X and clocked FX83's, so yeah...
So if I ran this bench mark my graphics score would less than someone with a 4930k
The graphics score is independent. Any of the intel i5s or i7s running at the same clocks will allow the cards to score roughly the same Graphics score. If you do score less on graphics score with a 8350 it means there is a bottleneck. The one thing you must not compare is the overall score as this will have Physics added in which gives the i7s an advantage.
Valley is an awful bench to use as it is rubbish on any decent GPU setup regardless of whether it's on an intel or AMD CPU, this is why I did not use it. Intel will get an advantage on it though.
Doesn't that in its nature make it closer to how games would be though? Not that I think synthetics are good for bottleneck testing.
Certainly not Firestrike.
I'll provide some comparisons in game benchmarks, if needed.
I have got to go to work now but if you and anyone else run the sleeping dogs bench (using the settings in that thread) with the 290P/Xs at stock that will also be a good comparison. I will run it tomorrow when I get in.
Firestrike is closer to a game than Valley is, another good bench that is very game like is Heaven 4.
I truly disagree on both points :p
If you want to test bottlenecks for games, you test games, it's that simple.
We've seen Haswell i3's barely bottleneck a titan in Heaven, how is that anywhere near a game :p?
Oh, now you've done it.
No offence Kaap, but I think you're doing far more harm than good in the discussion of bottlenecks :p
Running GPU intense synthetics for CPU bottlenecks isn't indicative of bottlenecks for gaming..
This ^
I've used a celeron on Heaven and had like 30-50 fewer points compared to a clocked 2600k (with a 670)
