- 12 Aug 2005
- Orpington.
Found them, can't link though as it's a competitor. They do laser and CNC cutting.
3dmark results these look ok?
http://www.3dmark.com/fs/1694174
Switch the cards about Shanks and see if that helps temps. I still wouldn't worry though, as AMD did same that 95c was well within tolerance.
Ghetto-mod a fan on the bottom to blow upwards. It won't intake any air, or much of it, but it will make the airflow from the cards go up to the exhausts.
Cards like these blow the air sideways mostly, and a bit to the back.. so you want to get the air up, to the exhausts.
Should help a few C's to be honest. Also, running top exhaust fans at higher RPM might help.
Do it, going to fit this very soon
P.S breaking 20k graphics with two GPUs is a very respectable score.
fit two.Ghetto-mod a fan on the bottom to blow upwards. It won't intake any air, or much of it, but it will make the airflow from the cards go up to the exhausts.
Would you mind keeping the side panel of your case off Shanks?
Awesomefit two.
. Could do lol. After this discussion I'm unsure whether to use it as an exhaust also but sticking to my guns
Willing just for a test tomorrow see if it does change the temps.
I kinder wanted a side window.
Hello guys got my new GPU's and case and my worst worryTop card is hitting 94c when benched with Heaven 4.0
Heaven score
https://skydrive.live.com/redir?res...uthkey=!AC6CgYKXslW0skI&v=3&ithint=photo,.png
Installed
https://skydrive.live.com/redir?res...uthkey=!AJ9YjsXA6ykvM8E&v=3&ithint=photo,.jpg
Temps 94ctop card
https://skydrive.live.com/redir?res...uthkey=!AMwW1MJKE0XomkU&v=3&ithint=photo,.png
Check that the fans on the cards are a actually spinning. My MSI R9 290 was suffering high temperatures and it turned out one of the fans wasn't turning. Ever since I gave it a push start it has been ok.
Andy
it's defo poor air flow on my half.
