@bauerCTU. You are not supposed to install the caps with the latest drivers. I suggest installing 13.3 beta 2 as they are suppost to be the best drivers for crysis 3. Until amd say so don't install any caps as they are now in the drivers.
Cheers noticed this about 10 mins before you posted so have un-installed them as im running latest beta's. Still cant get the GPU usage over 45% for the really dense grass area's. May OC the CPU see if that truly helps. Otherwise the game is running superbly blown away by the image quality.
