Sounds like this is the same issue with trying to mine with the stock BIOS on the MSI 290X Gaming Edition. It doesn't happen with the ASUS BIOS flashed, but with the MSI stock BIOS, it won't go to 1500 MHz on the memory or 1000 MHz on the core, without black screening or a driver recovery message. Unless the system is powered down totally and then cold booted, the card(s) aren't detected again.
http://forums.overclockers.co.uk/showpost.php?p=25801559&postcount=65
Sounds like the MSI potentially has the same OCP thing, as the card sails through gaming and benchmarking, but mining is currently not amazing with the stock BIOS.
Gibbo has been great to flag this up with MSI, so hopefully a fix will be incoming for all.
