Thanks, I already got better scores than that now but not enough to beat 8 pack yet![]()
Is CPU clock so essential in Valley or heaven? I do need to bring it up as high as possible anyway. Between that and the high ambient (girlfriend won't allow anything too low on the thermostat while she is in), it is hurting my scores. Managed a 140.5 on Valley a little while back though.
Ok tomorrow I try the the most out of my CPU before fiddling more with the GPUs. Hope I didn't get a dud.
Thought id increase my cpu clock to try and get my score past 3000, i got a lower score at 5ghz than 4.5ghz.
To be honest though id put that down to the 290, the scores don't increase as much the more you push the card and id set it at 1200/1500 for the 5ghz run but it was at 1200/1400 or something for the 4.5 run. I seem to get negative gaines increasing the memory on this card past about 1400ish.
Yeah indeed XA had 1.75v no problem. DC2 is the best Ti around.
Thanks thought I would do some forum benches on LN2 once I tried efficiency on HWbot Heaven test.
. Congrats on another record!
