How to tell Xbox movies, Xbox music etc to save to sd.
All the guides are for win8 not 8.1 I thought they made it easier.
I just went to desktop, file explore, properties, location tab and changed it to D. But the apps don't recognise any of the files there, just says nothing threw. If I go to file explorer I can double click the files AMD it launches in the right app, but does save info like where you are at.
This need fixing in the next update. It mould be as easy as opening up Xbox videos, charms bar, settings choose where to store files.
Edit - sorted it. Its terrible and needs overhauling. How they expect someone to know what's going on. That is a rubbish system.
It downloads the file to the hidden app folder in c users. Before putting it where ever the folder is. so you still need ~6gb spare on c:\ drive. I also fond out why 10gb on c also disappeared, had two partially downloaded film files in there, which should have been deleted automatically when the download failed/cancelled.
So sorted now, well as much as it can be.
