MSi gaming R9 270 fan oil leak?
3 Feb 2011
As I was taking apart my SG05 to change the front fan, I noticed traces of oil on the shroud of my R9 270, around the fans, this can't be good but I looked it up and seems like it's a common issue for MSI's gaming series card.
RMA time I guess?
I also ordered mine on the 24th. I noticed it leaking about a week ago and just wiped it off, after checking again today the oil seems to be all over the shroud and fins.
Guys why wait, get them RMA sooner not later and you should all let OcUK know too if that where you got them from.
Wikii Fluid Bearings, if it fails it fails fast and drastically where as a ball bearing is gradual.
I am not saying they are bad HDD's run cooler with them since they started to use 10yrs or so ago but if a normal bearing leaks some oil or grease it will not fail there and then but if a fluid bearing leaks all its fluid that is the actual bearing = bad.
When I opened up the box to my new EVGA 780Ti SC the other day I seen fluid on it but I realised it was leaking from me. :o
I got mine from OCUK, since I'm within 14 days return period, I'll probably return it for something else, with it happening on so many MSI cards, I don't think I don't want to deal with another MSI product.
Some reviews state the fans used on msi cards are two ball bearing from checking the model number. Evga also use ball bearings on their ACX cards.
