- 5 Sep 2011
- Surrey
Or just don't use dyes and use any clear pre mix and you can just drain and refill. Each to their own though
Which tubing would you recommend for use with Pastel? I used Masterkleer before, however after 2 years of use, it's slightly discoloured, and as I'm changing the colour of my coolant, it needs to be replaced, and OCUK don't stock Masterkleer anymore!
I would suggest this:-
http://www.overclockers.co.uk/showproduct.php?prodid=WC-116-PM&groupid=962&catid=1530&subcat=1777
In whatever size you need of course. Seems to resist staining and clouding pretty well by most accounts.
Mark
That is what I was leaning towards, but unfortunately it's out of stock in the size & colour I need (16/11, clear)
yes. It all depends again on how you build your system.
