Sniper Elite V2 Benchmark
Permabanned
19 Feb 2014
To
The standalone version from both sites I grabbed it from is 1.05.
I am not DL'ing and installing from Steam to bench this, game was completed long ago lol.
5 Sep 2011
Surrey
Just did a stock run, doesn't need to go on the chart but good for comparison with other scores
1440P
4960 @ 4.0
780Ti SC Ref 980/3500 Tri SLI
Sniper Elite V2 Benchmark Report
Created: 2014-02-23 at 15:41:04
Build Version: 1.05, Jun 7 2012
Average FPS: 94.3
Minimum FPS: 7.4
Maximum FPS: 579.5
Number Of Frames: 7204
Average Frame: 10.609ms
Minimum Frame: 1.726ms
Maximum Frame: 134.919ms
Machine Name: MICHAEL
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 32707MB
CPU: Intel(R) Core(TM) i7-4960X CPU @ 3.60GHz
Number of Cores: 12
GPU Name: NVIDIA GeForce GTX 780 Ti
Feature Level: DX11.0
Driver version: 9.18.13.3489
Dedicated VRAM: 2902MB
Resolution Width: 2560
Resolution Height: 1440
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
5 Sep 2011
Surrey
1080p
4960 @ 4.0
780Ti SC Ref stock Tri SLi
Created: 2014-02-23 at 15:46:26
Average FPS: 148.3
Minimum FPS: 9.4
Maximum FPS: 573.4
Number Of Frames: 11352
Average Frame: 6.741ms
Minimum Frame: 1.744ms
Maximum Frame: 106.760ms
Monitors: 1
System RAM: 32707MB
Number of Cores: 12
Resolution Width: 1920
Resolution Height: 1080
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Permabanned
19 Feb 2014
To
Impossible on this Batch lol.
I suppose I could put up volts etc and boot to 4.5GHZ (though not stable) and try bench but its a PIA to open case to press button to get into Bios as I am running Fastboot.
22 Nov 2004
3570k @ 4.5 / r9 290p @ 1225/1500
Created: 2014-02-23 at 18:48:01
Average FPS: 48.4
Minimum FPS: 23.9
Maximum FPS: 212.6
Number Of Frames: 3711
Average Frame: 20.641ms
Minimum Frame: 4.703ms
Maximum Frame: 41.855ms
Machine Name: JAMES-PC
Monitors: 1
Operating System: Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit
System RAM: 8137MB
CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Number of Cores: 4
GPU Name: AMD Radeon R9 200 Series
Driver version: 8.17.10.1247
Dedicated VRAM: 3072MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Caporegime
12 Jul 2007
United Kingdom
Hi,
Here is my crossfire run on 290p's Sapphire trix stock @ 1000/1300 with i5 3570k @ 4.3
Created: 2014-02-23 at 12:27:01
Build Version: 1.13, Apr 11 2013
Average FPS: 85.8
Minimum FPS: 30.0
Maximum FPS: 750.4
Number Of Frames: 6570
Average Frame: 11.660ms
Minimum Frame: 1.333ms
Maximum Frame: 33.327ms
Machine Name: STEVE-PC
Monitors: 3
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 8152MB
Number of Cores: 4
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Seems ok, to me, do you need a pic as well?
Fascinating results Jock and backs up my theory about me being pci-e bottlenecked on this benchmark as our clocks are all but identical yet you're many fps ahead of me on pci-3.0.
Permabanned
19 Feb 2014
To
@ Frosty, OC'd to 4.2GHZ, had to lower Uncore 3 notches to 39 (any more is pointless as performance drops) and volts to 1.35v and a few other tweaks and score was 63.7 with same GPU OC, (could be tolerance of another run and not CPU clock) not worth it IMO and not going to benefit me in Crysis 3 etc. so I need get a good CPU for that.
GPU drops to 1.0v-1.15v on load at times so the voltage control is not working in AB/Precision for the Ti properly.
Should have kept my Z68 Rog and 2700k as the refresh may be here by May.
Man of Honour
OP
21 May 2012
Dalek flagship
4 Titans @968/1789
3930k @5.0
1080p
Created: 2014-02-24 at 03:00:12
Average FPS: 204.8
Minimum FPS: 18.4
Maximum FPS: 1231.8
Number Of Frames: 15699
Average Frame: 4.883ms
Minimum Frame: 0.812ms
Maximum Frame: 54.213ms
Machine Name: TITANIV
Monitors: 1
System RAM: 16324MB
CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Number of Cores: 12
GPU Name: NVIDIA GeForce GTX TITAN
Driver version: 9.18.13.2018
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
1440p
Created: 2014-02-24 at 03:04:26
Average FPS: 122.5
Minimum FPS: 13.7
Maximum FPS: 1231.8
Number Of Frames: 9418
Average Frame: 8.163ms
Maximum Frame: 72.835ms
Monitors: 1
System RAM: 16324MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
1600p
Created: 2014-02-24 at 03:02:24
Average FPS: 113.0
Minimum FPS: 14.6
Maximum FPS: 1231.8
Number Of Frames: 8688
Average Frame: 8.847ms
Maximum Frame: 68.521ms
Monitors: 1
System RAM: 16324MB
Number of Cores: 12
Resolution Height: 1600
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
12 Jan 2013
Gdansk, Poland
1 x GTX 780 at 1095/1706 (Air)
i7-4770k Stock (Air)
Created: 2014-02-24 at 10:07:59
Average FPS: 54.0
Minimum FPS: 32.7
Maximum FPS: 193.5
Number Of Frames: 4129
Average Frame: 18.528ms
Minimum Frame: 5.169ms
Maximum Frame: 30.558ms
Machine Name: KOMP
Monitors: 1
System RAM: 8127MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
Dedicated VRAM: 2994MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
