Where is the first floor?
Status
Not open for further replies.
Pic or didn't eat it.
Unfortuntely, the garage near my work doesnt sell real Mars bars. this was the closest they did, but it tasted exactly the same.
How many cars are there?
2 again?
That's 3.
But your turn now answering my logic?
It's funny how if you are sky diving, you hit the ground, not the first floor.
If you jump off a building, you hit the ground, not the first floor .
If you jump off outside the window from the first floor, you hit the ground.
If you jump off a floor inside the building, you hit the first floor?
WHAT ON EARTH? What kind of logic is that? You are on the first floor just because you step inside a door?
HSBC in Hong Kong has no door as such on the ground floor, the entire ground floor is wide open. Just because you are inside the footprint of the building means you are now on the 1st floor? What if I am 1 foot in it, 1 foot outside? Am I both on the ground and 1st floor?
I like the folk in here who can't tell the difference between the number of floors and the number of storeys...
In terms of maths;
number of floors = number of storeys - 1
Are you American, Chinese or Russian Gilly cos otherwise i have no idea how a Brit could argue for the 1,2,3 rather than the G,1,2
Is our Sketchup friend Sang, really stood on the second stair? I guess he must be according to some people here ;)
And yes I did just render that :p
HSBC in Hong Kong has no door as such on the ground floor, the entire ground floor is wide open. Just because you are inside the footprint of the building means you are now on the 1st floor? What if I am 1 foot in it? Am I both on the ground and 1st floor?
Indeed. A door and walls do not created floors. Floors do.
Zero is pretty complex, some light reading about it can me found here:
http://en.wikipedia.org/wiki/Zero_(disambiguation)
Technically, we should count from zero. There are zero mars bars, there is 1 mars bar etc..
Zero is also used as a neutral number, it could be argued that the British ground floor convention has arrisen from this.
But really, you just need to look at the simple logic of Raymonds post
You start at 0. Up 1 is 1, down one is -1. It doesn't get more logical then that.
Starting at 1 doesn't make any sense at all. In order to have 1 you have to have gained something. That's why when you are born, you aren't 1 years old immediately.
Yes and no
I agree with the being born part
However......by walking into the building you have by default gained something. You have entered the building, 1st floor
walk out of the building, 0 - you are not on any of the buildings floors
Status
