Just did a Firestorm run. No OC on the Titans but 4.625 on the 3930K
Frames, Time (ms), Min, Max, Avg
136877, 891857, 84, 202, 153.474
Died in every vehicle going![]()
Impressive
So there I was happily getting owned on Caspian Border 2014 and suddenly, I was forced to look at the sky and couldn't look down at all, just a vertical stare...
Just a one off or have others had this?
Even when I got killed and respawned , I was still looking upwards.
Not heard of that one![]()
I don't have a user.cfg file![]()
Indeed Greg, always forget your at 1440p. Very nice scaling on what is a pretty demanding map.
Afterburner working grand here mate, beta 18 ver 3.0.0. Both gpu and cpu info in osd and g15 keyboard lcd.
 hottest temp was 48C on card three. Fans at 80%No probs mate.That makes sense and I do normally have fraps running. I will try it without thanks bud
Edit:
Spot on cheers Setter. Both GPU's working at 99%![]()
Lol, 48c, can only dream of that.I just did a busy play on Zavod with cards cheesing it at 180 FPS, the heat coming from them is nuclearhottest temp was 48C on card three. Fans at 80%
 Tbh though at 64c on the gpu im happy enough. Cpu though is a different matter. Hitting 70+ quite often, albeit this is a very hot running example of a haswell, (aka hades) chip.
