- 25 Nov 2011
- The KOP
14.2 and Battlefield they way it's ment to be played.
Stunning
Still has a bad memory leak. My HDD is thrashing after 15 minutes of playing.
Win 7.
The only problem i have with Mantle is a big cpu spike every 10 minutes or so, other than that it works well. Not sure if theres a memory leak or not as i can't enable monitoring overlays. I've not noticed one, but thats not to say its not there. I just can't get over how smooth it is, its complete madness. Another thing when you alt tab, its instant, like it happens so quick its just weird. On DX11 there is a pause.
Oh ffs. Have you tried it with lower settings chief??
Somebody mentioned that if you install 14.2 then play the game straight after it's fine (although I had the memory leak).
Rings true as it was fine yesterday today it's FUBAR.
Mantle is awesome for the few minutes it is working but it needs a lot of work.
I'm going to play some BF bad company 2....awesome game still.
Try deleting the Mantle cache files, located in My Documents/Battlefield 4/Cache.
That worked Matt. This has stopped the 'Battlefield 4 has stopped working' message when going fullscreen.
Doing some testing now, so far i've got the game on mostly high except mesh and effects on Ultra 4 x AA FOV 90 + HBAO...shanghai is pulling 110-160 fps.
I haven't run out of Vram with these settings.
Not bad for a 5 year old CPU and 2 year old 7970s![]()
What CPU are you running?
