- 5 Sep 2011
- Surrey
uhuh lol
You should defo flash the card
Are 780's / 780ti's monster clockers or something :O
Ok I uninstalled the Standalone and reinstalled my Steam copy to play the 3 DLC's I never knew about (played Hitler one) so v1.05 to v1.11
But my Logs have mad high FPS that cannot be true for those settings in the logs which are same as all others here and in OP.
The FPS do not match screen capture so I deleted the folder and now I still can still bench but have no folder with logs.
4 x 290Xs @1240/1500
4930k @4.7
Sniper Elite V2 Benchmark Report
Created: 2014-02-24 at 10:59:25
Build Version: 1.13, Apr 11 2013
Average FPS: 210.5
Minimum FPS: 18.8
Maximum FPS: 1147.7
Number Of Frames: 16076
Average Frame: 4.751ms
Minimum Frame: 0.871ms
Maximum Frame: 53.328ms
Machine Name: HAL5
Monitors: 1
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 16323MB
CPU: Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
Number of Cores: 12
GPU Name: AMD Radeon R9 200 Series
Feature Level: DX11.0
Driver version: 8.17.10.1247
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
It is a role reversal from the 680's being poo clockers (which in general they were) and the 7970/50 being awesome clockers (which in general they were) and now the 290/X are poo clockers and the 780/Ti are awesome.![]()
Though until I get a better CPU
Intel i7-4770k
