- 21 Oct 2013
Will test later, but I would assume that the signal will remain at that of the main displayed task, so snapped TV will still be at 60hz.
Yes, from what I can tell so far it switches to 50hz when watching TV full screen for the first time and stays that way until you fire up a game so as to not be switching constantly when moving back and forth between the home screen, I thought it may be quite jarring but seems quick and seamless.
It just needs a standard micro USB cable for the updateSettings -> System -> Update controller.
You do need a play and charge kit or some form of cable that will fit the xbox controller.
Anyone having problems with live can login but nobody is on my friends list and having feed error aswell
RadioNoggin said:Quote:
Quoting myself to confirm that after testing with Forza and snapping TV, this does appear to be the case, best solution as far as I can see, certainly wouldn't want snapped TV dropping games to 50hz.
Going full screen from snapped looks to be going to 50hz too, so all good.
I guess it would depend on how your tele handles the frequency change. My panny plasma will go blank for a second. I can handle that.
yeah that was my thinking also that it would go blank for a second im just curious to now if that was the case![]()
Panny plasma here, not a blank screen, but I have noticed a brief freeze-frame and/or stutter before the new signal comes into effect.
