I have just started to get the past day or two massive overheating problems with my AMD 6990 Sapphire.
Idle temps on both GPU Diode (DispIO)'s are hitting close to 90c to 100c (on idle or watching tv, light stuff in other words) and this just all of a sudden happened, no driver changes or anything, it just changed, infact the only reason why I even noticed the temperature change is because the fan sounds like a rocket engine !!!
I took the card out and used my VERY high powered electric blower to give it a real good clean out and also updated to the latest driver and latest Intel chipset drivers for my board etc, still the same thing happened
In safe mode the temps are perfect, that may be because the motherboard doesn't fully use the graphics card in safe mode, I don't know, does it ????
Anyway, for now it is working but very hot as I say and everything else is cool temps, but I am very scared it does damage to something else, when you touch the card it is so hot it literally scalds your fingers etc
This is a first for me with this kind of thing
What could possibly be wrong, anyone know or got suggestions, as I say, I have tried cleaning the drivers out the usual way using the programs to do that and reinstall the new driver etc, but still no joy and that's from AMD's site and also Saphire's site too, the drivers install ok but still same thing happens is what I mean
I am stuck at a loose end here and don't know what to do next, there is so much heat off this thing I don't even need my raidiator switched on in the room to heat me up that its so warm, I am not joking, but as I say, touch wood for luck, all other temps, cpu, Motherboard etc seem just fine (for now).
My specs are in my sig you will see.
hope someone can help please asap, cheers
p.s
anyone know the length of warranty on the amd 6990 sapphire, I bought it at full price within weeks or days of them being available for sale at first in the UK. ????
p.s
