- 7 Feb 2011
This is the thread for OCUK Forums Mafia Game 4: The Thirteen Doctors. This will be a role-heavy game for 13 players using relatively simple roles from the Mafiascum Wiki. Setup is closed, meaning you will not be told what roles are in the game.
RULES:
NOTES
If you wish to sign up for this game, please post. The first 13 applicants will be put into the game; anyone else will be listed as a reserve in case we need replacements.
PLAYERS
01 Brabbinho
02 Pookie Bear
03 Fortyseven
04 Kaiowas
05 Egon
06 iviv
07 Pudney
08 Leprechaun312
09 K1LLSW1TCH
10 shorttricky
11 chriscubed
12 Shamikebab
13 Psymonkee
RESERVES
A
B
C
Vote Tracker is here
RULES:
- Once the game has begun, do not post in this thread unless you are a living active player.
- You may not edit your posts for any reason, even to correct a spelling mistake.
- This is a MAJORITY LYNCH game. Once a player has received a majority of votes (AKA "been hammered") there can be no further changes in voting; that player will be lynched and the Day ends immediately. If no player receives a majority of votes by the deadline, there will be no lynch that Day.
- Please do not post after a player has been hammered, except to point out that the hammer has fallen if it wasn't obvious. Where possible, the last player to vote should say that their vote is the hammer.
- To place a vote, use the format ##vote <player>.
- To cancel a vote, use the format ##unvote. If you wish to change your vote, you must unvote first.
- Do not use bold text anywhere in the thread except when voting or unvoting.
- Players are expected to be reasonably active. At the end of each day, any player who has posted less than the moderator (Jedit) will be replaced. If no replacement can be found they will be modkilled.
- Communication outside the thread is absolutely forbidden unless your role permits it.
- You may not quote out-of-game personal messages from the moderator in the thread.
- Game Days will last a maximum of 48 hours (72 hours for Day 1), with a possible 24 hour extension at the weekend if traffic is slow. Game Nights will last 24 hours with no extensions.
NOTES
- All roles in this game are standard and fairly simple. There are no ******* roles or alignment-changing roles. If you have any questions about your role, PM the moderator (Jedit).
- Roles and alignments were determined before flavour was assigned randomly. Nevertheless, it is advised that players do not reveal their flavour.
PLAYERS
01 Brabbinho
02 Pookie Bear
03 Fortyseven
04 Kaiowas
05 Egon
06 iviv
07 Pudney
08 Leprechaun312
09 K1LLSW1TCH
10 shorttricky
11 chriscubed
12 Shamikebab
13 Psymonkee
RESERVES
A
B
C
