Man of Honour
- 16 May 2005
- Manchester
I've found I feel a lot less knackered whilst using them too. I was pretty dubious about them until I tested them out.
Seem to make a difference for me when I'm out cycling. Plus, "aspartame which is apparently carcinogenic at extremely high doses". Pure scare-science. Good luck trying to ingest enough aspartame to come close to a dangerous dose.
A bit of an oxymoron about wanting an electrolyte drink with no carbs. When exercising you NEED carbs to replenish your glycogen. Electrolye loss is fad science - you'll have to be sweating litres to lose electrolytes in a debilitating manner.
If you're going to be refilling as you go along, i'd go for the high5 tablets.
Much easier to take the tube with you and pop a tablet into your bottle each fill than try and package loose powder and measure out the correct amount into each bottle.
Unless you can find an easy way of carrying the power.
I have a vacuum packer so things like that aren't an issue.
Hmm..I don't get how that would help in this case? Perhaps I'm being dense![]()
Measure it out and vacuum seal it into little pouches. Then can just tear open and mix in. Think of it like ketchup sachet.
So the vacuum sealer doesn't just pull all the powder into it when you seal it? That's interesting. I'll have to experiment with my own sealer.
I guess it would keep them sealed and dry.
You'd need to measure out and pack the small amounts for each dose though.
I'm sure there are lots of ways it could be done. Taking a large pack and measuring it out as you go wouldnt be my choice though. Is it likely to be raining or windy? That could cause problems also.
I would rather get said energy from food, and not get into a sugar cycle and crash and burn, this isn't 30mins or an hour or two, is sustained. At, I'm doing 8-10hrs. On the challenge I'm hopping to do it in 24hrs of non stop hell.
And yes I am sweating litters. Last long walk I did, I had 5litres of water, not one pee and was still severely dehydrated for the last hour as I had run out of water.
And last year in summer (same day those soldiers died on the Brecons) was planning to climb two peaks, but only did one as went through my full 4litre water supply on the way down the first. Now have a water filter so can filter water when out if needed. Bit that doesn't solve the salt issues.
