£700 gaming pc
3 Mar 2014
Hello,
I am looking to build a gaming pc and have a £700 budget. I want it be easily upgradeable later and only need a monitor with it.
Thanks
What games do you play?
League of legends, Metal Gear Rising: Revengeance and Titanfall when it comes out.
Could you elaborate on that please? State a few examples of what you're thinking, as they will have an effect on the spec(s).
So if i get a better graphics card later on, it can be plugged in and run well with what i have already.
Is AMD as good as intel now?
+1 :D
Wont get better on that budget!
Not really!
Intel will always dominate the market, but AMD do have some good gear. If you're looking for integrated graphics on a budget, their APUs would be the way to go. The 6300 is a great chip on a budget, but Intel will always be king! :)
Doomed's build is what I'd go for ready, except the RAM, CL11 1600MHZ..
Unless you went second hand, there's no Intel gear worth getting at this price point to be perfectly honest.
That strider 700w has the same 12v ampage as my 500w be quiet L8 I specced.
The only difference is the BQ PSU has dual 12v rails.
The be quiet ones are also better made and quieter.
Where did you find that info please, Doomed?
According to what I found, the L8 500w outputs 456w on the 12v rails, and the Strider 700w outputs 630w on the 12v rail.
If it's accurate they actually have the same output then the Be Quiet is a bargain.
They are solid units, cannot go wrong!
