BF4 Lag Spikes
18 Feb 2013
Birmingham
Yes i know the games ****ed.
however im getting constant glitches every couple of seconds with makes the game unplayable, does anyone know a solution? (im running at a constant 60-70 fps on ultra settings)
welcome to the club :D
on the campaign i was stuck on the airport level due to me glitching under the map and into a sub water level. exited game restarted and i was still there. had to start from the begining
that totally sucks!, online i start to shoot someone facing the other way then some how hes already killed me or stabbed me :S
I stoped playing BF4 since xmas. Allow all the rage. Just not worth it. Dump the game.
On Virgin Media? If so you're probably in an over-subscribed area.
edit: Also, your sig is against forum rules. You may want to change it before a mod sees it :)
Single player or multi?
If your truly maxed out you will be running out of VRAM for sure, your fps sounds to high for ultra unless your in SP.
bring up the rendering graph by entering render.perfoverlayvisible 1 and look to see which line spikes when you lag. Yellow spike is CPU, green spike is GPU. Work from there.
looked at your spec you aint running that fps on ultra.
so if you want to play with that fps without drops do what most do in bf4 play all on low and mesh ultra.
you probably getting big dips as your card will be dropping to 45 on some big maps with lots on.ultra too much for that card.
okay so iv tried putting all my settings on low and mesh on ultra, yes its a lot better game play however im still getting mega spikes every couple of seconds.
my fps on low and mesh on ultra stayed around 120-130, and "render.perfoverlayvisible 1" is not a command in the console...
Also my ping always stays under 40 so it cant be my internet
what the hell is happening, im constantly running at 130 fps now and a ping below 30 at all times. why the BEEP do i keep getting huge lag spikes every 5 seconds!
could be if on normal hd
could be windows 8.1
could be punkbuster
maybe try deleting reinstalling pb (totally no trace before reinstalling) i had similar issue on first go on win 8 with bf3 turned out to be pb.
I get lag spikes that feel like rubber banding. I "hard reset" my virgin medi "super" hub and its gone. have to do it once a month or so.
okay so iv tried hard resetting my router "virgin super hub", iv tried uninstalling PB totally and they didnt work.
Finners i put the graph on and the cpu and gpu line are always following each other even when there's a spike of lag.
Register on this site and set up a ping monitor. You'll have to wait 24 hours to see the results.
http://www.thinkbroadband.com/ping
Post the graph/image in here and we'll be able to tell you if it is your connection.
Flush your DNS mate and open NAT on your router.
